Discuss 2 way dimmer switching in the Electrical Forum area at ElectriciansForums.net
J
J_c9sh
Hi there, would I be correct in saying that you can get 2 way dimmer ( dimmer at each end working against each other) but it needs to be a specific type, I think it's master and remote. Is there any additional wiring required and where would be the best place to get them
John
I know you can buy two way dimmer switches, but I think they work independently. Master and slave? Never heRd of it but this doesn't mean anything. Probably someone at the electronic bay will sell you one. Whether there is special wiring required depends on the manufacturer's instructions, however I would assume itmis straight forward ( again, I might be wrong) :gettree:
You can buy a 2 way dimmer switch but I think you can only have one dimmer switch on the circuit, so you would have a normal 2 way switch at one end, and a dimmer at the other.
Anybody please correct me if im wrong.
Just had a noisy. Looks like a standard 2 way dimmer switch will only work with one on the circuit, Master and Slave dimmers will both operate one light fitting.
Thanks Archy
GET make them - one end is the dimmer, the other is a retractive switch which turns the lights on or off, or dims if you hold it down.
Reply to 2 way dimmer switching in the Electrical Forum area at ElectriciansForums.net
