Discuss 2 way light switch wiring help in the DIY Electrical Advice area at ElectriciansForums.net
fedele
Trying to wire a 2 gang 2 way light switch and I have 2 cables, both cables have neutral(blue) and brown(live)? where do i put the cables on the switch. I can get one to work but when i copy the other cable to the other switch they dont turn on.
Please help!
pics attached.
I doubt that black is a neutral. Does that switch actually turn a light on and where are you trying to connect the LED strip.
Reply to 2 way light switch wiring help in the DIY Electrical Advice area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
