Discuss 2015 built nursery building with no RCD protection to undersink water heaters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening all, I was doing some repairs to emergency lights in a school and when I went into the switch room to find the fuses for the lights I found the heating board by mistake, reading down the chart I soon realised my error but then saw that there was no RCD protection to the 15 or so heaters that had been installed, am I missing something it is my understanding that these should be backed by an RCD, happy to be in the wrong if someone can put me right!
ps. of the 8 emergency lights I was called to look at 5 of them didn't have the battery pack plugged in!
You say it's in metal conduit? If it is installed correctly and has the correct Zs for the final circuit no problem?
Let's jump on the needs a RCD bandwagon
I was under the impression that somewhere in the regs there was a section on water heaters and RCD, however the regs book has changed several times recently and I no longer have the little sticky tabs in it that I used to have, I also thought that as it was a nursery school building it would have been as safe as it could, I don't have a reg number otherwise I wouldn't need to ask the question. and I did say in my initial post I was happy to be wrong, never to old to do some learning.
Under the impression that it's somewhere in the regs?
Why not open your regs book and find out for yourself?
What do you mean by 'as safe as it could', what unsafe situation are you thinking of that an RCD would improve?
An RCD won't help a nursery aged child, they will almost certainly be dead long before the 30mA threshold.
if I could find it in the regs book I wouldn't be asking would I, I am presuming that you are helpfully explaining that it isn't in the regs, which would be the reason i couldn't find it and that you personally feel that it wouldn't be required. Thank you for you response.
You are presuming wrong, I'm the forum's own resident psychopath.
I am suggesting that an electrician should have a good working knowledge of the current wiring regulations and keep themselves up to date with the changes as they happen, and so should be able to at least support their statements with reference to said regulations.
Reply to 2015 built nursery building with no RCD protection to undersink water heaters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just carried out a pre-work survey (older property and I wanted to check it over) for a client that wants a few extra sockets and other bits and...
Hi all, need some opinions on the following please> Origin is a three phase 60A TN-C-S supply.it goes into a changeover switch (small PTO driven...
6K
Hi Guys can anyone help out here, I've just been to look at a lighting fault in a children's nursery which I've now sorted but my question to you...
I am an old school Leccy having done 24 years in the Royal Navy as an electrical/electronic engineer (Control Electrical Mechanic) maintaining...
M
Just after some advice if I may, I was asked to go look at a job this evening at a local hairdressers. the flat above had a leak and damaged some...
Guest111
G
