Discuss 230v single phase motor in the Canada area at ElectriciansForums.net
spud,- you're asuming a capacitor start-run motor ,there are other ,less used ways of doing it (but your'e probably right :))
sorry for being thick when you say red/blue together ........do you mean the motor or the supply cable ?
You are right Wayne, realised what i had said after posting !:rolleyes:
hi
Red and blue together would be correct if it has a capacitor ,but it will still work connected the other way ,if it goes the wrong way reverse the field connection:)
atvbitwww
I take it he is saying single phase motor on three phase supply. Dont single phase motors usually have the start and run winding internal to the motor and you simply take a phase and neutral from star as live and neutral? so red or yellow or blue for phase and black for neutral?
Reply to 230v single phase motor in the Canada area at ElectriciansForums.net
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Looking to use this brooks Compton motor as a replacement in an electric cement mixer. can anyone tell me if it is designed to operate off a...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Hello Everyone -- So, I am looking to buy a used 5HP 3PH 208 V 10 inch Table saw --- (Motor Plate Data in Image) I am a DIY'er and in...
