Dannydigger
Hi Guys,
Im currently quoting a job to install dimmable downlighters.
Firstly, can I use 240v downlighters with dimmable LED bulbs
Secondly, can I use a standard dimmer switch or does it have to be a low voltage one?
Thanks as always
Dan
Hi Guys,
Yes you just buy GU10 LED lamps.
For an increased chance of compatibility, trailing-edge dimmer switches tend to work better with the capacitive load of an LED driver.
Thanks as always
Dan
Also some dimmers have a certain wattage range, need to make sure you're within that range.
Im completely baffled. Ive got 9 240v downlighters with 5W dimmable LEDs. Do I use a 400W dimmer or lower rated one?
Stumped
Well, you can't fix stupid!
Read the manufacturers information for the dimmer to find out what LED load it can work with.
LED loading cannot be calculated the same way as a traditional Incandescent or a Mains Halogen light bulb. A good ‘Rule Of Thumb’ to apply ,is to take the maximum rating of the dimmer switch and divide by 10. Or the manufactures instructions will provide more accurate information than the rule of thumb method.
Lee does that mean if I have 9 x 5W LED (45W total plate load) I will be ok with a dimmer that has got a min plate load of 40W?
use brain for thinking. buy the lamps and dimmer together from same place.
My post was about the maximum loading of the dimmer when using LED lamps. For example a 500W dimmer will normally be good for 10x5W led lamps but the manufacturers instructions might say you can have more.
Most trailing-edge dimmers have a low minimum load often around 10W.
had a very good results with bg nexus dimmers recently, they have a little adjustment at the back, to set maximum dimming level, so the lights dont cut-off. toolstation sells them. worked fine with a lot of 8 generic 5w dimmable leds purchased in there too.
