Discuss 25 year old boiler wiring in the Central Heating Systems area at ElectriciansForums.net
Andy5678
Been looking at changing a faulty timer on an oil boiler.
the current timer switches between DHW or DHW and HTG.
I cannot find any motorised valves, it looks like it’s just controlled with a room stat connected to a pump for heating and some other stat I can’t find for the water.
had a look on google and can’t find any diagrams that would suit this and the model of programmer that’s installed just now is not available.
anyone had a similar problem?
Sounds like a gravity fed heating system, comprising a 2 channel programmer, pump,room stat and a hot water cylinder stat. Most 2 channel programmers are capable of this but there is normally a small dip switch on the back of the programmer which needs setting to gravity fed system
[automerge]1576784766[/automerge]
From memory these are referred to as hot water priority systems
Cheers, that looks like the one I need. I have just got no idea where the cylinder stat is... will go back and hunt a bit more.
the pump was down stairs under the shoe cupboard the boiler further along in utility room and the hot water cylinder upstairs with no sign of cylinder stat.
I have the dip switch setting on the new programmer.
Is the oil boiler in an outhouse, if so the other stat could be a frost stat.?
And it could be wired the traditional;
Hot water demand from programmer = Boiler only on (hot water temp is whatever the boiler is set to)
Heating (and hot water) demand from programmer via room stat = Boiler and pump on.
No Motorised valves used.
Are you sure there is a second stat? When I moved into the house I'm in many years ago all that regulated the water and house temperature was the temp setting on the back boiler (Baxi). I soon fitted a tank stat and room stat. The previous owners said it was always lovely and hot in winter. I hate to think what the gas bills were like. I currently use a Drayon LP522 timer. It's got the DIP switch on the reverse for gravity feed systems.
A gravity system does not use a cylinder stat and it is not a hot water priority system.
The programmer DHW channel directly fires the boiler, the CH channel feeds the room stat which feeds the pump.
Reply to 25 year old boiler wiring in the Central Heating Systems area at ElectriciansForums.net
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
A nice easy one for all the (many) people that are cleverer than me 🙂. Could you please point me in the direction of a wiring diagram for a...
