Discuss 3 phase 12kw immersion in the UK Electrical Forum area at ElectriciansForums.net
B
badgered1
Would you use heat resistant flex if fitted in a flexible conduit?
It's a 4 wire connection.
I'd prefer to use 4mm but I can't readily find it in harsh environment spec.
Ta
Ah when I said flex I really meant multi stranded flexible singles, but I think I've got it, standard cable comes rated at 70oc but another rating common is 105oc
Sounds like a politician, “What I meant to say was, (waffle)”. Or it could be, “I was miss quoted when I referred to……….”
It helps if you refer to the electrical wire sort of thingies in a precise way that mere mortals can understand.
You tell us Harsh environment and dont expand on that, how can we suggest a suitable method when we lack the parameter info or were you just generalising harsh because its gonna get warm.
Reply to 3 phase 12kw immersion in the UK Electrical Forum area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
What are people fitting in the 3 phase range just lately, I've had a scan at various makes and it seems to be a ---- up between Hager and Wylex at...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
I am trying to understand 3 phase volt drop. I understand single phase VD. Lets say we have a 70 meter run of 35mm, 5 core cable from the supply...
