Just didn't think you we're ment to rely in the dno's service fuse if the tails where over 3m long, do see your point about having 2 fuses in series though and down fusing would limit supply
Be best to check with the DNO as they dont usually like fusing cables that long
Sent from my GT-I9300 using Tapatalk 2
As it's an incoming supply, shouldn't you be looking at a four pole isolator? Fused or not as the supply dictates.
