I was asked to run 3 phase supply when I was wiring both steam room and sauna, so I did. I didn't know the load requirements..................
Need I say more mate..................if you don't know the load you can't run anything and I'm being nice:)
Thank god I got in before the 'god' electrician read that:).
And
No................I didn't mean you Wade:)
so I'm 2nd fixing a large house in north london, weeks ago I ran a 10mm 4 core (3 phase) cable to the steam room and the sauna in opposite sides of house, each going to a 3 phase isolator, at the time I didn't know the load requirements and so I chose 4 core as precaution, I only need single phase at each of these locations, my question is do you think I should still install 3 phase MCB in board on each of these cables or fold back the un neeeded phases at the board as another electrician has suggested to me? may sound like stupid question but I've never been in this position before, I don't see a problem in conecting them in 3 phase MCB's as they are properly connected in 3 phase isolators at other end. what to do you think?
change of direction, will the customer be happy to pay for a new 3 phase board in both areas?
didn't realise the worlds greatest electrician was here, how are you? sorry for my utter ridiculous question, let me elaborate, I was asked to run 3 phase supply when I was wiring both steam room and sauna, so I did. I didn't know the load requirements as i have not ran supplies to these before. when it came to it they only needed sngle phase, I have the 3 phase isolators fitted and I'm left with 3 phase cable at the board so I thought put them in 3 phase mcb, as opposed to what? putting them in connectors or something, i dont like doing that. i'm thinking now I better just jack the whole trade in as I clearly dont know what i'm doing, despite the fact that i've been working full time a electricin for years and hae been getting nothing but compliments for my work, but then i could never be as good as you your worship, or your mates on here, dont waste any more of your time on me
Hi mate it just seems you haven't got your head round this 3 phase mullarky yet.
Just because you have 3 phase cables/isolators and D/b's etc doesn't mean you have to have a 3 phase supply connected to them.
You can still connect single phase to all that lot and it will work fine........but still connect the 3 phase and Neutral cable.
It just means you only have 1 live 'active' and the rest can be connected at a later date if and when required.
Just mark/label your boards and Isolators accordingly:)
Double edit.............2 lives 'active'...........1 phase and neutral:)
I dont understand what everyone is finding difficult about this? get your head around this, I'm working with two large commercial style boards with 3 phase in each, when it came to wiring the sauna and that I enquired about the load, I was told it may need 3 phase or single phase, I ran 3 phase but then weeks later it only needed single........ the cable is going into an isolator (3 phase) with a single phase load going to steam gen....at the 3 phase board i am left with the 4 core cables, it doesnt need 3 phase mcbs but since i have the cable I wondered what to do with the extra cores if not to connect them into a 3 phase mcb? am i making sense yet?
look, im not havin a go but without knowing what the max demand`s goin to be...well...
but as far as running a 3 phase supply is going...as has been said already....
so sorry about the initial abruptness....but as your in just check out some of the posts in here just lately from folk just droppin in
I dont understand what everyone is finding difficult about his? get your head around this, I'm working with two large commercial style boards with 3 phase in each, when it came to wiring the sauna and that I enquired about the load, I was told it may need 3 phase or single phase, I ran 3 phase but then weeks later it only needed single........ the cable is going into an isolator (3 phase) with a single phase load going to steam gen....at the 3 phase board i am left with the 4 core cables, it doesnt need 3 phase mcbs but since i have the cable I wondered what to do with the extra cores if not to connect them into a 3 phase mcb? am i making sese yet?
use 3 single phase MCBs....2 will be redundant....the other one will be your supply to the load (single phase)....
and dont forget you can just leave out the 2 redundant phases top end....but get them secured so as someone cant just start making em off and energising...
Use 3 cores of the 10mm2 armoured and coil the 4th up as a spare, the third core can be the CPC, then just connect to a single phase breaker, the other end I assume is a rotary isolator? if so just connect the live and neutral through it and connect to the single phase kit, simples
why did you not check the steam gen before buying up the three phase gear. Might have saved you a few bob too :)
We're not finding it difficult mate we're trying to explain so you can get your head around it..........as in help you:)
I can run a 3 phase 2.5 mm cable .........simple.
But if there's a 37kw motor on the end of it it's not going to work is it?
Well it might buzz for a second lol
thats fine man, what your forgetting is I didn't include ALL the info in my original post, do you seriously think just decided to run a 3 phase supply to sauna without enquiring about the load? c'mon, I have 3 phase in the house, I asked the sauna people what supply they wanted they said 3 phase or single phase, i ran 3 so as to be adequate for future changes. I was then going to connect these cables at my 3 phase board into 3 phase mcbs, then my collegue (electrician) said i should only use a single phase mcb and fold the others back, i dont like doing this
That's fine then...............what load did they say this 3 phase supply needed per phase?
You haven't mentioned Amps or design current once?
btw mate............is it PME supply?
