Hi Darkwood,
So, you know better what you got there.I hope everithing it is all right .
Whatever, keep up the good work. Thank you.
bertt.
Yes correct a VSD chops up the wave form of the supply and re-builds it as required any any waste is dumped down earth hence the designed leakage.... as ive found a 1.5kw and aove usually is large enough to cause nuisance trippingon 30mA rcd's
