DurhamSparky
going for a job interview tuesday and well i have got to do a trade test
stuff i should know but have not used it for a while!! as i never really needed it..!
had a good heads up so far but 2x Niggly stuff which i not really had much to do with..!
Star / Delta Motors...! am i correct in saying delta is when the phases are connected i.e
L1 - U1 - W2
L2 - V1 - U2
L3 - W1 - V2
and the following Test carried out for insulation are IR MEG Ohms L1 - E / L2 - E / L3 - E and or Continuity set to Ohms and between same points....
and just racking my brains a IR test can only be carried out on the phases if you have each side of the phase available..!
shoot me down in flames if you need...! alternatively correct me!
the other niggly one is relays and time delayed relays but i will just blag that one lol..!
L1 - U1 - W2
L2 - V1 - U2
L3 - W1 - V2
