Discuss 350 KVA HV Transformer? 3 phase calculation confusion in the Australia area at ElectriciansForums.net
santidreamer
I need to buy a 3 phase HV transformer for an apartment block
1382 Amps is the total predicted single phase load after diversity.
1 Phase KW
1382 Amps
230 Volts ( I/V)
317.86 KW
KW 1 Phase KW to KVA
317.86 KW
0.9 Power factor ( KW x P.F. = KVA)
353 KVA
KVA Single Phase to 3 phase conversion
KW = V x I x 1.73/ 1,000
1382 Amps
Divide total load by 3 load per phase
460 Amps per phase
400V
1.73root 3
319 KW
3 Phase KW to KVA
318.KW
0.9Power Factor (KW x P.F. =KVA)
354.KVA
So 500KVA transformer. Needed
Reply to 350 KVA HV Transformer? 3 phase calculation confusion in the Australia area at ElectriciansForums.net
I have a 230 Volt single-phase circuit with a 100 Amp cutout fuse and a 100 Amp MCB switch, so the supply is rated at 23 kVA. Only about 13% of...
6K
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Hi Everyone May be someone could shed some insight on the sizing and provide some suggestions: 3 phase Generators (400 V, 50 Hz) have the...
Hello everyone, I really hope this isn't an idiot question but boy, I'm out of my depth! I've spent about 3 weeks (not solid mind) trying to work...
Hi Everyone I would be glad if you could clarify this for me: For a Load Estimate Survey whereby 95% is single phase, the Load Estimate is 90...
