Discuss 45/50A SD5 HRC fuse needed in the UK Electrical Forum area at ElectriciansForums.net
t01474
Hi everyone. I'm doing some work on a farm and came across a problem. The DNO head has 60A fuses in but down stream of that is a 3 phase MEM Glasgow switch fuse with 100A fuses fitted. Obviously there is no discrimination whatsoever there so I explained that the fuses need to be downrated to 50A max. I'm struggling to find 45/50A fuses with 94mm fixing centers and wondered if anybody knew where to get them. Failing that i'm thinking of fitting links in the Glasgow and installing a 45A Glasgow?
Reply to 45/50A SD5 HRC fuse needed in the UK Electrical Forum area at ElectriciansForums.net
Nothing much has changed with them since the beginning. Perhaps now a lot of things come with moulded plugs and you don't need a screwdriver to...
Hi, I have been asked to fit a ringmaster cooker and wanted to confirm everything I plan to do is correct. I'm sure it is would just like to...
HI, I am hoping someone on here can help. I am looking for a fused inline mains connector plug... capable of taking a 5 amp fuse / 240 volt feed...
5K
I'm in desperate need of a few meters of fuse wire in 100A, 80A, 60A, 50A, 20A & 15A. I can find a few suppliers that sell the smaller values as a...
R
Carrying out an inspection on a victorian style Multiple occupancy house split into 4 flats. Each flat is wired in 10mm2 bare pyro clipped direct...
Deleted member 26818
