Discuss a CLEAN power supply to a music system????? in the UK Electrical Forum area at ElectriciansForums.net
I
irish ivan
hi all
I,ve got a curious one for yee.
went to view a job this evening, the client wants a fuse board upgrade.. yeah ok no pobs!!!!
the other thing is he wants a CLEAN power supply to his music system. reckons current drawn by other appliances on the circuit causes noise on the sound system.
I kinda understand what he,s talking about I,m thinking it may be similar to a clean earth for computer system or am i way off????
im thinking a 16amp radial might help a bit.
hi all
I can see you ending up married to that job lol, "Audio phools" will pay silly money for things like "oxygen free" cable with "enhanced insulation" which they can hear makes a difference to the sound, run forest, run :) lol
Use some of these on the cable for a squeaky clean supply.
nah most so called audiophile's are guilible.
the interference will be from the amp to the speaker. using screened cable to the speakers would be better.
i lol at people that try to act like audiophiles and dont have a clue, most people couldnt tell the dofference between a £100 and £1000 set of headphones let alone speakers.
power cables should be kept away from the speaker cables and it will be fine.
put a separate radial in, one end in the consumer unit, another one into a good quality metal socket (for the looks)
charge £££.
or split the tails and put a separate consumer unit to terminate that radial into. charge more £££.
some good reading here:
Mains Quality
Isolating tx and a TT earth.
What i have to laugh about is that most of these so-called ''Audiophiles'' that reckon they can hear the differences between one component and another are usually in their middle to late 50's and the silly buggers don't realise that both ends of their hearing range has been going downhill since they were 30. The only differences these buggers can actually distinguish between, is what they see on a spectrum analyser or other electronic measuring device....
WTF!! Nearly £580 for an RCA Lead.
Have you seen the £65/metre knitted singles for wiring 'ring mains' or the £25 each. 'Superfuse' 13A plug fuse?
Then of course the £1K+ IEC (kettle) leads.
His non-electrical stuff is pretty amazing too, the expensive lumps of wood to stick under your speakers to make them sound better are a treat! (This does have an effect on subs, acoustic compensators are sometimes used in theatre for this but they are the same random offcuts of ply we use as packing for rostra and bits of scenery)
I had an argument with a guy about HDMI leads.
"It's a digital signal mate. It either works or it doesn't."
"No no no no, i had a hdmi lead that was really bad quality, then i bought a 3m lead for £150 and it was amazing."
"No it wasn't."
"What do you know."
"I know how to crimp a hdmi lead and fault find, i also know its a digital signal and it either works or it doesn't."
Reply to a CLEAN power supply to a music system????? in the UK Electrical Forum area at ElectriciansForums.net
Hello, I am currently DIY upgrading a caravan with my girlfriend but need some advice. The (very old) 230VAC to 13.8VDC power supply broke down...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
Hey everyone, lately I've been trying almost everything to reduce the electrical noise over my Be Quiet Straight Power 11 850W 80+ Platinum PSU...
Hi Everyone, I'm new to this forum and am hoping someone can give me some advice, as I'm absolutely clueless when it comes to these things. I'm...
