Discuss A quiet bathroom fan - any recommendations in the UK Electrical Forum area at ElectriciansForums.net
JLeague
I was looking for a bathroom fan with timer that was quiet and there are the usual makes - manrose, Xpelair etc but I came across Blauberg - never heard of them before - anyone used them?
If you do need a through wall unit, I would recommend a ventaxia Svara. Not cheap, but very quiet and highly configurable via app for timer, light levels, humidity etc. If in an exposed location will definitely need a backdraught arrestor though.
Manrose 100%
NOT !! . Either a nicely fitted inline or my favourite wall /ceiling fan of all time is Xpelair C4 fans .Excellent .
My parents house comes with a very quiet airflow regulator
it’s called a window (I’ll get my coat)
anyone remember air bricks. ventilation for the room and also the cavity? noticed next door had all theirs blanked off with duct tape. pillock.
I went for a
A quiet bathroom fan is a good quality in line fan, sited remotely. Never fit these noisy through the wall things if at all possible.
Double the performance, and only just perceptible that it's running, if installed correctly.
It's finding the space I assume is most peoples issue.
In the past I've fitted a couple of Airvent 100mm Quiet Extractor Fan Timer (item 15514 at Toolstation) and found them quite quiet compared to what was in there before. But, they are 'kin long at the back - not a problem if going into a straight duct, but one of my installs had an elbow and I had to fit a couple of spacers to drop the fan down off the ceiling to give enough length before the bend.
This looks very much like an axial fan, which is not suitable for feeding into a duct of any length, other than just through a wall.
Reply to A quiet bathroom fan - any recommendations in the UK Electrical Forum area at ElectriciansForums.net
Hey all, This weekend we are discounting a range of bathroom & extractor fans. All of these products are currently in stock for fast delivery...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
This weekend we are offering up to 42% off some of our best-selling silent + timer extractor fans. Hurry as these prices are available for this...
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
My very well off customer wants the most quiet ceiling mounted extractor fan there is. They have stipulated that cost is not a barrier and they...
4K
