the muppets make up wright the regs .its like the book of bull s**t the bible.
I'm not sure the people who write the regs are really muppets. The regs have flaws, I grant you, and like all standards are incomplete and always will be. But it is a massive challenge to write, in one book, a standard that covers every single situation, device, risk, method and safety feature found in electrical work throughout the country. You could write a whole book just on accessibility for maintenance. They have to deal with conflicting demands from different interested parties - legislators, manufacturers, electricians, architects - and come up with a compromise. Would you rather they left room for manoeuvre or dictated everything? 'Make nice joints' is too vague, 'The box shall be secured to the joist with two 3.5x25 gold-passivated countersunk woodscrews 20 +/-2mm above the plasterboard' is too prescriptive. Somewhere they have to find a balance, and in doing so they get called muppets...
My version is that if damage to decor or fitments might result or significant making-good is required after access, or it takes much longer to access than to check/correct the fault itself, then it's not accessible. I don't fit carpets, and I don't want to have to call a carpet fitter to refit a valuable carpet properly after I've gone poking around under it for a disconnect. Thankfully I don't touch domestics.
I also agree that a craftsman can make a sound, permanent, maintenance-free joint with a good quality screw terminal box, but given that either or both parts of that equation might be lacking...
Well said Lucien. It works both way, though.
This was a rfc, wired in pyro with neutrals extended, in a Schneider 12 way 3 phase board, following upgrade to rcbo's .
Given a choice between a screw or push fit connection,whether the joint was under a floorboard or not,I would not use a push fit connector
I know nothing of them only through very limited use,however,via the little I have experienced,I have found there is no way I would be content to have a joint I made constructed with those connectors
If I used a screw connection I would be much more confident of its suitability and its performance
I like the lever connectors and have used them. They are especially handy during fault finding...but I can't see them being a more solid connection than a properly fitted brass/copper/brass screw connector.
yes but Electrical Trainee can push a wire in even if they can't tighten a screw properly. all part of the dumbing down. by the 21st edition, monkeys will be able to be electricians.
The industry must be preparing early by the payment of peanuts!
They look like the Ideal In-Sure® Model 33, www.idealindustries.co.uk/product/12/204/67899/.html which are 32 Amp rated, so one can assume there was a problem with the wire not being fully inserted or something?
The Ideal 2, 3 & 4 way ones are 32 Amp, which is why I use them, as they can be used for ring main cables.
So can a 20A as generally a ring final circuit is designed around the assumption of a load at 20A at the furthest point of the circuit and the remainder to the rating of the over current protective device evenly distributed around the ring final circuit.
Surely if the ring provides power to the kitchen & utility, then someone further down the line does something wrong to break the ring, which is not picked up until the next EICR if they bother to have it done, then those poor little 20 Amp connectors will be the weakest link & will fail before the fuse or circuit breaker disconnects?
