Discuss addditional sockets to old ring mains in the Australia area at ElectriciansForums.net
L
leekemp85
I have got a loft conversion to do next week, when splitting the ring and adding lights do they need to be on rcd even though its only minor works, no new circuits.
Its a old wylex fuse board but they don't want to pay for new board
In a word, Yes
in stead of splitting the ring can you use an rcd fused spur to feed loft power?
so long as the addition is to new specs existing can stay as is if they are on a budget, check / upgrade bonding though.
Hello.
As in Lister's reply, you add extend the ring or add a unswitched spur to the ring which will feed any power and lighting you want. But make sure that all new cables you install meet current regs requirements - so if in doubt, make sure it is an RCD spur you install so that all new additional wiring is covered.
If it's an old style ring circuit, what type of cable is in use ?
Make sure water and gas bonding are up to scratch with regs.
But then you'll need to test circuit that you've added the extra bits too - a minor works certificate.
New regs make everything so much harder ( I only need to add two sockets and light to the old circuits), I am only an young electrician but I would bet any of you have not had any problems with your own work in the past whether it was 14th, 15th or 16th edition regs.
RCDs are a brilliant invention for long leads where there may be a higher risk. But in a standard extension were common sense should prevail ( ie, do not hammer a nail above a socket or switch)
common sense seems to have gone out of the window the the staff that wrote the 17th edition.
Sorry to go on but its frustrating when you price to do a job to regs, then a cowboy turns up and does it at half the price to the 1st edition works ok but wont pass any inspection and you could never find him/her when something goes wrong.
I don't even want to think anymore about the part P scheme surely there must be a better way. I know someone that did not finish his collage course but is now a "part P" electrician :mad:
anyway I am now in a good mood after posting that, if it makes sense I have been for a few beers:)
Reply to addditional sockets to old ring mains in the Australia area at ElectriciansForums.net
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hi all, I’ve had some good advice here in the last week or so which has made me ask a few more questions. 1. Ring main uses the old Red and Black...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
