B
bobbert
Hi Guys,
Need some points clarifying with regard to adding a fused spur outlet to an existing household ring.
The ring and in fact the whole house is not 17th - ie: no rcds at all.
If I'm extending the circuit to include a new spur outlet am I right in thinking that an rcd will be needed at cu as exisiting ring is buried in walls so I will need to bring circuit I am working on up to current regs???
Also, I am right in thinking that PIR will needed for ring circuit and MWC to cover addition to circuit or would this be EIC as I've changed the protective device?
Sorry if this all seems blatently obvious ... I'm new to all this and want to get it right as I'm looking to go NICEIC soon.
Thanks.
Thanks.
This didn't make sense to me.
