Andy5678
Here’s a commercial scenario for you to comment on over you nightly dram.
So there is an existing consumer unit with older style MCBs or bs88 fuses. RCBOs cannot be added to existing and customer wont pay for a new consumer unit.
My soloution is to add a garage unit onto the side. Remove main switch and feed singles through to RCBOs. Use multiple supply label, 400v etc
Anyone got any better ideas?
An additional RCD would be sufficient and eliminate having two OCPDs of the same value.
Where would the second supply come from to necessitate a label ?
When it comes to commercial or industrial, especially, it can be worth taking into account what problems could be caused to work output by covering a full power circuit with one rcd unit. In such situations, rcd sockets are the option, dependant upon wiring methods, of course.
