• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Advice on faults and Ideas for fixes in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Any idea why the blender has tripped my downstairs breaker? Annoyingly when the extension was built they took the lounge feed and extended it round the kitchen but never bought it back to the CU (Concrete floors maybe put them off) So when the CU was upgraded this year a different sparks could only throw in a 16amp fuse as opposed to a 32amp. Could it simply just be a matter of to much on the circuit when the blender is running with it's 1560w motor?
You definitely need a 2nd opinion, especially if you are holding money back..
Before engaging somebody to rectify his work though you should give him notice of what the issues are and the opportunity to rectify them himself
@Murdoch - None yet. Should i ask for any if it's just socket/switch replacements and a security light? I'm not really up with when to request them to be honest. Sparky's not finished the job yet though so nothing as of yet. The sparks hasn't technically finished the job yet, but my plan was to arm myself with some good questioning and recommendations to see what answers i got back when i bring it up.
@Pete999 - NAPIT Membership and insurance. Is it enough for this type of routine domestic work?
@Beefy
so if he's coming back would suggest an email to him with some questions and highlighting some of the "snags" ............ best keep it between you and him for the time being.
As for testing & certs, if new cables have been added / extended then yes I would say a certificate is necessary.
@Murdoch - I think your right, one socket was added additionally and an extension from an original socket to the loft socket was added. I'll keep you posted. Would i be right in simply asking for the switch that controls the security light to be troubleshooted. Sounds like i'm stuck with raising the plug socket due to the majority saying that extending it is a bit dodgy?
I don’t think raising the socket height is an impossibility.
If cables come from above, easy to shorten.
If cables come from below, I would think a wooden floor. MFT joint under the floor and a spur up to socket.
Worse case is concrete floor. Just make your joint in the old box and put a very flat blank plate over it.
It does sound like the spark is out of his depth. And his “solutions” make him out to be a bit of a t!t.
I'm sure I said something like that on page one. agree whole heartedly.
@littlespark - Thanks. What's an MFT joint sorry?
@James the Spark1976 - You did, which is affirming for me. Cheers..
The reason i've opted to do it this way round. ie. reach out for advice prior to emailing him is that i've already has the answers to the questions in a round about way. Howeverm he has asked me to let him know of any issues prior to the last visit to finish off 2 small pieces of work. However without the electrical knowledge and being able to make suggestions and challenge the reasoning, the email/discussion could be a bit one sided.
I'd like the job to finish with the outstanding issues resolved, however if he turns round and says, "well.. Thats your parts" or " I can do that, but i feel it's outside of the quote and could take days to rectify" or "I can do that, but it's going to be very destructive (even if it's not)" then armed with a little knowledge i can help sway the convo.
the socket that you want moving up should not be an issue. joint cables with crimps or soldered joints, heat shrink over, plaster in.
as for certification, should be a MWC ( minor works certificate) issued on completion.
MFT = maintenance free termination.
Basically a joint that doesn’t need to be accessed in the future.
Crimps, as @telectrix mentions or spring loaded push in connections.
Screw terminals in the old choc block are not classed as maintenance free
Thank goodness for that, I thought for a moment you had left your MFT under the floor, which would make for rather an expensive job.
Finally somebody states the simple and obvious. Why can’t this cable be crimped and sleeved. Absolutely no need for MF junction boxes.
Reply to Advice on faults and Ideas for fixes in the Electricians Jobs area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
