J
Jon Hodgson
Hi guys, wondering if anyone can help me with a problem I've got with a kitchen.
The problem is the isolation point for a double oven, there is no wall within the 2m distance where the isolation point needs to be located.
The location for the oven is on a return run of units that joins onto a run of units that's glass from the work top up. By the time a complete wall is available the distance between the oven and that wall is 2.5m at a minimum.
A few possibilities I have are to mount the isolation point on the end panel for the run under the worktop, or to locate a modular popup to use on it but all in all its proving a bit of a headache.
Does anyone have any ideas on how to over come this?
Jon
Jon
