The last couple I bought were from eBay.
They were fine. Cheap too.
Are these exact ones definitely suitable, they are only 47Ohms which is less than others have stated is necessary. What is the implication of this? Higher current across L&N when switched on therefore more consumption and possibly heat, but also better able to discharge smaller induced currents?
Thanks, Tom
The current when energised is determined almost entirely by the reactance of the capacitor, which is much higher than the resistor. The main purpose of the resistor is to limit the peak current on transients. If the snubber is used to suppress switch contacts or a semiconductor switch, or as a dummy load to bleed off leakage, it limits the current when the switch closes, which saves wear on the switch. It also protects the capacitor from fast-risetime spikes on the mains damaging the dielectric.
Therefore the resistor value is not very critical in this application. Too low (a few ohms) and the switch suffers wear, too high (a few kilohms) and the benefit of the wattless load of the capacitor is lost and more heat is dissipated. The worst case peak current on a switch closure is uo * sqrt(2) / R so I would tend to go for 100 ohms or so to keep it to just over 3A. I would be more interested in the quality and durability of the cap than the value of the resistor.
