S
Squid
May The Power of Laugh Be With You,when all else fails, call in:
Where did you dig that one up from?
Apologies if you've already given this detail - how often is the dimming, how deep and duration?
I love a fault - much more interesting than TV![]()
Main tail are in reverse live and neutral, probably mixed at the meter when they changed the tails
Reverse polarity!! Energy savers
I should say that it has been noticeable on LED GU10 bulbs, and also on the old energy saver types (not LED - the ones that looked like small tubes in a loop). It was just more noticeable on the filament type bayonet bulbs. I’ve replaced all them filament types with LED bayonets now and it’s no longer noticeable on those lights, but is still happening on the GU10 bulbs in the kitchen, bathroom and bedroom.Politely disagree.
I don't think it would be reverse polarity. The OP said it was ceiling lights as well as table lamps. Likely to be bayonet cap fittings - doesn't matter which way round they're put in... and also said it happens with filament lamps... not 'energy savers' in the sense that if they are CFL or LED.
And between the electrician, his return visit and the ones that came to check the supply, someone would have visually noticed the cables being reversed between the meter and the CU.
Would a data logger pick up a blink/flicker like this? My instinct tells me a slightly loose connection.The OP had the DNO out to data log so that would and should have picked up something supply side.
I don’t know but I’d like to think so as a diagnostic tool. Maybe a member has experienced the positive that a data logger produces.Would a data logger pick up a blink/flicker like this? My instinct tells me a slightly loose connection.
tinternet. it's a marvellous tool.May The Power of Laugh Be With You,
