gazdkw82
Just about to start pulling in the cables for my smile detectors, however I dint have the detectors yet. Is there enough room in the terminals to terminate a supply feed in and then loop out to the next detector or is a junction box required to house the feed and a supply taken from every J/B?
They are not exposed, there’s a cover over the cables, there’s no cables exposed once the smoke head is removed.
think hemeant where the cables enter from the back. you need to keep the sheath stripped part quite short.
i'd not call this loads of room when you have a T/E and a 3C/E in there. just about enough.
me neither, but you need to strip back no more than 1" of sheath. or it's difficult to get the cover on. that's probably why i find a few knocking around the bottom of my toolbelt. :)
funny that. last week replaced a duff one. bungalow only had 2, both square. tight fisted client would only stretch to replacing the faulty one, then complains he can't obtain a square one and the new one exposes the 30 year old patch of wallpaper on the ceiling that was under the detector. still allcredit to aico for making them compatible with ancient ones.
I could never get the rectangular type smokes square haha
gazdkw82
leicester
United Kingdom
Electrical Engineer (Qualified)
Aico smoke detector wiring
gazdkw82,
Mike Johnson,
