Discuss AIrflow icon30 humidity timer pull cord problem in the UK Electrical Forum area at ElectriciansForums.net
TheCodboy
Hi all. Having trouble with the module on the icon30. Never fitted this particular type of module before,usually just the normal timer type. Fan stars up with the lights as it should,but as soon as the lights are switched off the fan stops. Fan is fed with 3 core & earth as normal with S/L L & N. Am I missing something here? The pull cord is for a boost I believe? Any advice would be much appreciated.
Which module exactly are you referring to?
Thats the one we have in our utility (I think)
The pull cord will activate the timer and run for a period of time
The humidity sensor will only start the fan when it hits the moisture level.
I don't think it will come on with the lights.
I
”adjustable timer with momentary pull cord override”....
I tried S/L in the L terminal and Permanent live into T. Came on with the lights ,then off with the lights. Pull cord does nothing when it’s running or not. Swapped the 2 lives over,runs continually and pull cord still did nothing!! I’m not sure if it faulty as there’s no real defined “click” as you would get from a pull cord.
The pull cord is ON only, you can't stop the fan using the pull cord... only the timer can do that (or your isolation switch).
I would recommend you set the timer to a very short period and see what happens.
Don't put the cover on - then you have access to the terminals too.
Hope this helps
Hope this helps
So if I connect a perm L to that fan,the pull cord will operate it and the timer will turn it off?
Hope this helps
By the way,the customer supplied the fan & module... wouldn’t have been my choice for his bathroom.
So your customer has bought a humidistat fan with pull timer .... Not ideal for a bathroom , but OK for a utility.
Icon fans are, in my experience, well built and very reliable products. Not cheap, but you get what you pay for!
Think I’ll tell him to just put a timer module in. Wouldn’t think anyone would want a pull cord hanging from their new bathroom ceiling.
The actual wiring diagram for the module,does show 3 connections.
Permanent live,neutral,and switched live from the light.
I have had a few of these type of components,fail to work straight out of the box,just make sure you follow the setting up procedure,in regard to initial adjustments.
I cannot remember off hand,what brand was to blame,but a plumbing pal of mine,called me a while back,as he was doubting his wiring,having had the same problem with a second,new module.
They were both faulty :)
Reply to AIrflow icon30 humidity timer pull cord problem in the UK Electrical Forum area at ElectriciansForums.net
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hi guys, I'm an apprentice electrician and have been doing some basic work on my bathroom with what I've picked up on site. I've split the mains...
Hi, I am trying to move my pull cords from the bathroom to a outside switch. I have a pull cord that controls a light and fan together. the...
5K
Doing some testing today on a Wet Room installation. Fed from its own small CU. And consists of 2 x seperate 50A (for 10.5kw shower) circuits...
A few weeks ago I posted this in another thread...: The tripping kept occurring, so I went back and moved a likely candidate circuit to the...
