Discuss Alternative dimmable transformer with dual input in the Lighting Forum area at ElectriciansForums.net
sarahm
Please help!
A number of my mother's lights in her kitchen are no longer working and I suspect the transformers need replacing as I had a similar problem in our kitchen that I fixed by changing them.
I took a couple of her spotlights out to see if she could use the same transformers as I have but it appears hers have a dual input (2 live, 2 neutral, 2 earth wires) for some reason. They are Aurora AU-60T 20-60W/VA dimmable electronic transformers.
I have looked online and it appears they have stopped making the same transformer so I am really hoping someone can suggest an alternative we can safely use without having to rewire her kitchen lights. I can only find single input transformers.
Thank you so much!
Reply to Alternative dimmable transformer with dual input in the Lighting Forum area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hello, We moved into our house 2 years ago and until recently the kitchen lights worked fine. The LED strip lights are on a dimmer switch, when...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Hello I have recently moved home and I looking to upgrade lighting across the house to LED. In the kitchen I have found that there is installed...
