Not aiming this at any one respondent, but Dave makes a valid point.
AM2 can be daunting for trainees and when this guy posts a question two days prior to his test, the majority of reponses have been arguing over irrelevant details.
Whatever the AM2 spec states is exactly what candidates are expected to do - opinions to the contrary don't matter and deviations from spec may result in a candidate failing that section. Failure rates are high.
With the amount of help given over the last fifteen years or so, can the odd casual remark not be taken with pinch of salt?
I can't see many jumping out of their seats to offer help....or comment, even.
It didn't used to be unusual to use pyro fixed with P clips to tray. Hence the nuts and washers, with brass screws. P clips opened and formed into U clips to fix rows of two or three cables or solid copper band for multi cables, cut, formed and drilled for fixings.
At least this was an effort to explain regarding clipping on tray.
As I stated, the comment wasn't aimed at any particular person and you did go on to provide an explanation. I'm not the forum police and people are free to post as they please, but it was worth pointing out that the guy is heading for his AM2 tomorrow and may well be stressed about it.
I've found it strange having to use P clips in this situation, but there's no reason why it shouldn't be done if called for in a spec.
No problem and nothing aimed at your comments.
Hope he stays cool and passes......and doesn't get a question regarding P clipping.
It is bit daft if you have no screws to help fit them all.
Screws ? Or did you mean bolts :)
I've never seen a 4mm brass bolt - all have been screws. Bolts have an unthreaded section part way along the shaft, starting from the head.
The only brass bolts I've commonly come across are supplied with clamps for earth rods.
What’s wrong with 6mm brass nuts and bolts for banjos?
For me, a bolt doesn’t have a screw driver head. It’s the way you interpret, same as umpteen other items.
That's a type of screw, not a bolt, as the first line of the description alludes to.
Its actually listed as a bolt
M4 x 30mm Hex Bolt Full Thread in solid Brass - DIN 933
The defining distinction, per Machinery's Handbook is in their intended purpose: Bolts are for the assembly of two unthreaded components, with the aid of a nut. Screws in contrast are used in components which contain their own thread, and the screw may even cut its own internal thread into them. Many threaded fasteners can be described as either screws or bolts, depending on how they are used.
A correctly specified bolt used to join two accurately machined components together will allow minimal lateral movement. Substitute a screw, lateral movement can occur and the stresses in the fixing will increase, sometimes to the point of failure.
Hex bolt Full Thread is an oxymoron.
I always used the definition that a bolt was only part-threaded, while a machine screw was fully threaded.
Normally a bolted fixing is held under compression so the threaded/un-threaded aspect ought not to alter lateral movement. If accurate alignment is needed you could attempt to use the un-threaded portion but really at that point a properly fitted dowel is going to do a much better job.
While it is tenuous to call it "electrical work", you see some microwave parts with dowels fitted as the active part is so small and needs such accurate alignment that typical screw/bolt arrangement is just not good enough. For example:
