Jul 2, 2023
19
Manchester
Trainee Electrician
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the tray using:
  • P Clip
  • Nut
  • Washer
I’m just a bit confused about how this should look and which parts should be on the “inside” where the cable runs on the tray and the outside (if that makes sense)?
Just don’t want to drop marks or even fail because I’ve in correctly used P clips as I’d find that quite embarrassing to say the least.
If anyone could please explain how this should look or even any pics I’d be really grateful, AM2’s on Monday and I have enough to worry about as is other than P clips.
Upvote 0
It is bit daft if you have no screws to help fit them all.
Screws ? Or did you mean bolts :)
I've never seen a 4mm brass bolt - all have been screws. Bolts have an unthreaded section part way along the shaft, starting from the head.
The only brass bolts I've commonly come across are supplied with clamps for earth rods.
Upvote 0
Upvote 0
Upvote 0
What’s wrong with 6mm brass nuts and bolts for banjos?
For me, a bolt doesn’t have a screw driver head. It’s the way you interpret, same as umpteen other items.
Reactions: mainline
Upvote 0
Don't you go spoiling a potential 3 day argument 😂
OK, I’ll bolt off.
I’m sure MK didn’t know what he was starting.
How’s it gone today by the way, MK?
  • Funny
Reactions: nicebutdim
Upvote 0
That's a type of screw, not a bolt, as the first line of the description alludes to.
Its actually listed as a bolt
M4 x 30mm Hex Bolt Full Thread in solid Brass - DIN 933
The defining distinction, per Machinery's Handbook is in their intended purpose: Bolts are for the assembly of two unthreaded components, with the aid of a nut. Screws in contrast are used in components which contain their own thread, and the screw may even cut its own internal thread into them. Many threaded fasteners can be described as either screws or bolts, depending on how they are used.
Upvote 0
A correctly specified bolt used to join two accurately machined components together will allow minimal lateral movement. Substitute a screw, lateral movement can occur and the stresses in the fixing will increase, sometimes to the point of failure.
Hex bolt Full Thread is an oxymoron.
Upvote 0
I always used the definition that a bolt was only part-threaded, while a machine screw was fully threaded.
Normally a bolted fixing is held under compression so the threaded/un-threaded aspect ought not to alter lateral movement. If accurate alignment is needed you could attempt to use the un-threaded portion but really at that point a properly fitted dowel is going to do a much better job.
While it is tenuous to call it "electrical work", you see some microwave parts with dowels fitted as the active part is so small and needs such accurate alignment that typical screw/bolt arrangement is just not good enough. For example:
Upvote 0
No, I just hate seeing trainees put down for the sake of making someone else feel big and clever
Blimey! Still at it. :rolleyes:
Ever remember being an apprentice?
Upvote 0
Manchester
Trainee Electrician
AM2- Clipping cables to tray with P clips?
ManchesterKirchoff,
ipf,
Electrical Courses
