Discuss American Bosch grinder to work in the UK. in the UK Electrical Forum area at ElectriciansForums.net
P
prospect
Hi, i have just purchased an American Bosch tuck-point grinder from the states. This is the only place that Bosch sale these for some strange reason. I also purchased a step down converter so i could run the tool here, but when i plugged it in it seem to run at half the speed. There are only 2 wirer's white and black. Is it possible to fit a UK plug or will i need to have a new cable fitted so there's a neutral wire also. I dont want to damage the tool as it was not cheap. Thanks for any advice given.
Not as easy as changing a plug! Fortunately when I moved from Adelaide to England it was a matter of just changing plug tops, as they have similar supplies ie 240/50 etc :)
You might have a frequency problem rather than a voltage one. Have you contacted Bosch technical for an opinion?
Assuming the tool is designed for 120V (which is what would be supplied by your step down transformer), you would need to ensure that the transformer is capable of supplying the current required for the tool.
If the grinder is a 1000W (1kW) grinder then you would need a transformer capable of supplying 1000W, many small transformers are only rated at 45W or so, you may be overloading the transformer.
White and Black are the standard US colours instead of Brown and Blue in the UK.
If you change the plug to a UK plug and plug in a 120V to a 240V socket you will damage the grinder.
might be an idea to fit a 110V plug and try it on a site tranny.
They may have converted it already as they knew it was going to the UK???
I Googled Tuckpoint grinders and there seem to be load in the UK SEE.... 1775E 5" Tuckpoint Grinder | Bosch
The USA has 120 and 220v available but I wouldn't think they use it for power tools. Normally the 220( between phases) is for large fixed loads like Aircon or Heating.
that guard can be bought seperately seen them for sale made to fit any grinder.
I think the fequency may be wrong, isn't America 40Hz?
60Hz is standard in the US.
I would also contact the suppliers and explain your dilemma. Running the machine on incorrect frequency and voltage would have unpredictable results at best and catastrophic results at worst.
Another option is you might find a variable frequency drive with 230v 50Hz input and 110v 60Hz output if you hunt around.
Hi,I have a 110 V Yankee grinder from Sears,its worked for years off either standard UK transformer(110 V) or a generator/welder 110 V output.You dont need an extra wire for neutral,its the black one,White being line.The frequency wont make a noticeable difference to its function.Happy cuttin/buffin/brushin...
Glad it's working. Usually if a motor sounds good and the running temperature is sensible chances are it will be okay. Might be worth just checking the run current with a clampmeter and making sure it's within the stated current on the motor plate.
Reply to American Bosch grinder to work in the UK. in the UK Electrical Forum area at ElectriciansForums.net
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Looking for advice for the following: Bosch Induction cooktop model NIT8669SUC ) came with 3 bare wires (Black, Red, Green) but my wall has a 4...
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
