Discuss Angles on PVC Trunking in the Electrical Tools and Products area at ElectriciansForums.net
RDB85
Trainee
I’m doing a large install with PVC Trunking I had a Magnusson Mitre block but it’s not that great with a large hacksaw.
Does anyone have any recommendations on what to use and a decent saw?
Manufactured bends, then you can be as hacky as you like…..
I’ve got one of those tin snip type tools with a mitre plate. Leaves a clean edge, not all burred up that needs filed smooth.
Not a fan of the bends. They are okay in some places but I want to make this as neat as possible.
4" battery Angle Dangle, chop chop, Bob's your auntie's sister.
If your wall is in any was shonky, even the slightest shonkiness, and mitred corners will be a pig unless you use CA glue and activator spray, which to be frank is a pain in the small donkey.
I know it’s not robust enough. But I at least want it to look good. I will be filling in and around with caulk. I’m just after some tools etc to make the job that much easier.
What type of installation as well
Is this something surface in pvc trunking with 20mm drops or what is it ?
Anything big I ever did was steel so not that familiar
What about this sort of mitre saw? Cheap and provide accurate cutting at any angle - downside is how much space it takes up.
Personally, working with trunking 25 x 16, It is never going to look like a Michelangelo. I use the separate clip on angles you can get to form any angles and terminations. I also think that the cutting of the trunking is less important than the lid. If you cut that right and as you say caulk it then that is as good as it gets. If you are using trunking you must know you cannot make a silk purse out of a sows' ear.
I’ve seen these, but I’m not sure if they are any good.
Deal: FLORA GUARD Miter Shears - 45 to 135 Degree Multi Angle Trim Cutter, Gasket Shear for Cutting Soft Wood, Plastic, PVC and More, Including 2 Spare Blades FLORA GUARD Miter Shears - 45 to 135 Degree Multi Angle Trim Cutter, Gasket Shear for Cutting Soft Wood, Plastic, PVC and More, Including 2 Spare Blades : Amazon.co.uk: DIY & Tools - https://www.amazon.co.uk/dp/B07SHBYDDP/ref=cm_sw_r_cp_api_glt_fabc_dl_0KNQDB5N83EQ56TCHCPQ?_encoding=UTF8&psc=1
Saw:
https://www.NoLinkingToThis/p/magnu...VSOztCh2x7wpUEAQYASABEgJZQfD_BwE&gclsrc=aw.ds
Mitre Box:
https://www.NoLinkingToThis/p/mitre-box/7048v
Reply to Angles on PVC Trunking in the Electrical Tools and Products area at ElectriciansForums.net
Is anyone aware of any galv trunking that is smaller than 50x50. I'm drawing a blank online. I've taken over a job that's used 16mm twin and earth...
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
I have a Dewalt 54v angle drill, the DCD470. It's a bit on the big side and I'm wondering if anyone else has one and if so what do you use to...
I have bought a Mini Mitre Block for some Trunking as the cutters I have are better for Mini Trunking. I’m just looking for something that will...
8K
