Dannyg8810
Once completing a annual emg lighting test is it a requirement to complete a cert or can this just be logged in an onsite ppm folder?
BS5266-1:2016 contains a model periodic inspection and test certificate (not called a Report) which can be used for the annual checks. I don't find this overly informative so we have devised our own and incorporated the checklist from the model certificate for verification of existing installations with an "Actions" section. The check list is handy if you are not overly familiar with emergency lighting design but you should have a copy of the relevant British Standard/s. You should also record your annual test in their log book if available.
