We brought two identical ( even down to the hands free kits , van tubes and colour ) Astra 1.9 cdti sportive vans in Jan 09 .
My one has done about 70,000 which is around 8000 less than my other director as mine is only used 3 days a week .
How ever it dropped a gear box at 28,000 , sprang a rad leak and slipped it's cam belt at 58,000 then again at 68,000 and has just done it again , luckily it's a safe engine and is just a bitch to start when it does this , just remembered the battery just goes flat over night every so often .
Any way the point to this is when it slipped its cam belt the first time i had to use the other one to nip down to just by the side of stone henge to pick up some bits , and the power difference was amazing .
It felt like it had about 30 hp less power but where mine does about 320 miles to fill up his gets up to 480 miles and has only ever had a problem with leaking rad once !
Just shows you can still get the Friday afternoon home time on the production line motor still !
