R
RAD
Good Evening.
I have a couple of jobs which I am currently quoting for that require panel heaters, one being a garage conversion and the other a log cabin. I just wondered if anybody had any good recommendations for 2/3kw panel heaters with built in thermostats? One customer did also mention a heater with child safe touch temperature feature?
Thanks for any suggestions you guys have.
Not the cheapest but I have always found the rointe heaters to be good. They also do a grille cover to keep little hands away
I’ve just fitted Rointe Delta heaters. Wi-fi or remote control and a built in child lock.
Yes, they’re expensive.... but to comply wit Lot-20 you’ll find any new heater will be.
How can you still buy plug in heaters from big sheds for a fiver?
