Discuss Approved vs Registered in the Business Related area at ElectriciansForums.net
N
ngoodson1969
Hi all,
I am new to this forum and just wondered what the difference is between being registered with (Eg) NICEIC and being Approved by the same organisation. Does being registered mean that you haven't yet been assessed for the two jobs or whatever the criteria is? Thanks.
Just to say, my name is Nick and I live in Brighton and am soon to become a domestic installer!! All going well.
Cheers in advance.
Nick
Nick
I started off as a domestic installer with the niceic then moved to approved contractor a year later I've been registered with them for four years theirs not much difference the costs are the same but there is minimum qualifications for approved contractor obvoiusly your scope of work is then all the red certificates which include fire alarms emergengey lighting etc it all greatly depends on the scope of work you do but my adivce is if you can meet the requirement for approved then go for it.
Regards Russ
Sorry nick forgot to say im new to the site too also give me a shout if you need advice on getting through your assessment
Hi Russ,
Just a quick questiion.
I am trying to get on the NICEIC domestic installer scheme. A friend of mine said its Almost impossible as its really hard and they want to see 3 jobs all near by. A major job and minor job.
Is it really that difficult? I have just finished an installation 1st and 2nd fix of an office/storeroom at the end of a long garden ( approx 44meters). Would this be enough to show? The install includes a main isolator at the main building, amoured cable along the garden ( buried ), new c/unit in storeroom / office. Is this enough or do I need to show them other jobs?
Thanks in advance
Sav
Hi Russ,
Thanks in advance
Sav
I thought it was two jobs you had to show within 30 minutes of each other?
One job that needs a MWC and the other a full EIC.
So use your install as above and extend a lighting circuit,or swap a socket in the kitchen or something on another job,even your own home.Thats the way i read it anyway.
Or better still phone them and ask them exactly what they need.
Domestic Installer Scheme (Part P) - NICEIC Schemes - Approved contractor scheme - NICEIC Group
Hi Russ,
Thanks in advance
Sav
Yeah you are still gonig to need another two minor works jobs to show such as extra socket etc.
they might only look at the major one an one other but still require three.
One more thing that job above has it got an earth rod fitted ?
Agreed phone them and ask ! when i done mine i ran a new supply to my garage inc garage cu and sockets/lights etc had to change to replacing my main house cu as they wouldnt exept the garage install only the supply cable from house to garage was notifiable as this was a distribution circuit so worth confirming with them first.
as to the assessment not as bad as you think ! i know a guy who passed in 45mins he done his main cu and across the road a loft light he wasnt asked many questions or had much testing and hes with NICEIC (no joke) mine was 3hrs aprox and the guy came from oxford there not there to trip you up just for your money ! as long as you have the kettle on and all your certs/books/ins/test gear etc etc your be ok ! their give you more advice than anything. Bottom line if you know what your doing and do it by the regs your pass no worries.
Good luck !
Regards
Kung.
P.S. Its 2 jobs ! 1 minor 1 major as on NICEIC website approved contractor will be more.
Reply to Approved vs Registered in the Business Related area at ElectriciansForums.net
I have been working as an electrician under an NICEIC Approved Contractor for the past 10 years. I have my C&G2365 level 1/2/3 (acquired before...
Hi all Quick question - I'm going self employed as an Electrician's mate as from the start of November. For this purpose, I'm looking to get rid...
I saw a Fluke 1653B on Gumtree local to me being sold as faulty. Fault was stated as no continuity between 'N' and 'PE' ports on the resistance...
I did a domestic installers course around 10 years ago (blimey time flies!). This is a level 2 qualification. I then registered with Stroma who...
