W
waqasahmed
Hi,
I've got some EU plugs where you can't simply replace them with a UK one as well as a toothbrush which has two prongs
Would this be safe for an EU charger? - Pretty much exactly as pictured
www.aliexpress.com
Or this for a a toothbrush adapter? I bought one for about £1 but it's an easy picture
www.aliexpress.com
Or this for a schuko plug?
www.aliexpress.com
I'd rather get something that's absolutely safe where I have no real option but to use an EU plug or if I've got a toothbrush with two prongs. If these aren't safe, what would you recommend as valid alternatives?
US $0.81 15% OFF|European Euro Eu 2 Pin To Uk 3Pin Power Socket Travel Plug Adapter Converter international plug adapte pop socket plug adapter|Electrical Plug| - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
0.71€ |Adaptateur prise d'alimentation électrique ue à royaume uni, type boîte ronde à deux broches 4.0mm conversion à 3 broches prise de rasoir avec fusible 13A | AliExpress
Achetez malin, vivez mieux! Aliexpress.com
2.91€ 20% de réduction|Connecteur de fil ue à royaume uni, convertisseur de cordon d'alimentation universel, 250v, 16a, 13a, mise à la terre, adaptateur BS | AliExpress
