Hi Revolt3k
You shouldnt need to test lead for RCD testing as if the RCD opperates in required times then you know the leads fine as well and if not a quick continuity test using a multimeter will still prove lead is ok. But if you mean in refferance to your question about the testing at the isolator a live RCD test it will contravine reg 14 of EAW regs so only perform RCD tests at socket outlets mate.
Regards
Kung.
Ok i see what your saying but the RCBO is for a lighting circuit so no socket outlet.
Hi
You can do the test at isolator cpc crock to cpc n-n and L-L or you can do it at CU cpc crock to cpc bar N to N bar or rcbo and L-L output on rcbo less far to walk to reset rcbo ! Also remember to check test button on rcbo.
Regards
Kung.
Hi
Regards
Kung.
yeah i was thinking the C.U way but wanted others ideas. Many Thanks again
At this moment in time this topic is the most useful to me, I am in the same position as you revolt3k, (I even have the same tester as you) and in the process of arranging my jobs for my NIC assessment.
The test procedure you wrote at the start of the topic I was very impressed with.
I’ve been told by others that the assessor may only ask for some of the tests on the chosen circuit and not every test from beginning to end. Is this true or ******** ??
Its true as he wont want to stay long as he will have others to assess or will want to get home.
P.S. Watch the language.
Ok J, Thanks, Ill watch my potty mouth in the future.
Cheers
Thanks Sid, Im glad im not the only one in this situation and im glad it helps others too to understand what is required etc. :)
