Discuss Audi 80 92 2.0 l serious battery drain in the Auto Electrician Forum area at ElectriciansForums.net
Audi 80 92. 2.0l. Serious battery drain in the morning tried to turn but not enough power from battery.jumps easily runs ok stop turn off then turn on same problem.won't turn .bought new battery same problem.alternator checked no problem mechanic says it's charging battery ok.any help would be nice.thanks
Measure the drain current to confirm excessive drain, leave the meter in and remove fuses one at a time until drain goes down. It always used to be a light stuck on in the boot or glove box but with modern electrics it could be anything.
When you locate the correct fuse what do you do next?thanks
Check the service manual to find what is connected to that fuse and investigate which load is draining current and why. If, for example, the heated rear window is taking power all the time you check out the switch. If it's the engine management unit then it's time to get someone in.
If you're not comfortable reading a car wiring schematic, and they're hard work at the best of times, then it might be prudent to get help. A car battery can supply a lot of current and it's easy to fry the wiring loom and anything connected to it.
After market alarms and stereos 10years after the install can cause havoc in a car, check boot light glove box light are not staying on also get one of these to whittle down to which the circuit drain is on you can also get one that connects to your meter/fluke.....
Someone looked at the battery today and said the black/earth connectors aren't secure enough !he suggested putting a nail in between the connectors and terminal.I wasn't sure about this!should the connectors be replaced ?they look well used!thanks
It's possible for a poor connection to prevent the battery charging properly but it would be hard to tell just by looking. You're right that bunging nails in isn't good practice. The connection needs a large surface area of clean metal, it doesn't have to be very tight. If you can't rotate the clamp on the battery terminal by hand it's probably tight enough.
It might be worth giving the terminals and clamps a clean with Scotchbright or the like and see if it makes a difference. If you decide the clamp is past it then replacement is the best solution. (Link to some clamps on Amazon)
Have you measured the current drain from the battery with everything turned off? That will tell you if there's a problem with the electrics, regardless of the state of the clamps.
I'm thinking that the charge going from battery to engine isn't strong enough.it starts with jumper no problem .drives fine.if I stop turn off engine.restart a few seconds later same not enough power to turn engine over.so could a small leak from one unit do this.could it be old cables and clamps from battery to stArter be the problem.?Thanks .The alternator has been checked and correct charge was measured.thanks
No that doesn't sound like a small discharge, it sounds like a bad battery or possibly poor connections. When you do a jump start do you connect to the battery terminals? If so the wiring from the battery to starter is probably OK. Do you have access to a multimeter? Without measuring voltage you're working in the dark.
try ohm meter across battery - to engine block. should read almost 0 ohms.
Ground connection is always a prime suspect but if the jump start works well with the leads onto the existing battery terminals it tends to rule out battery wiring, at least to the starter.
It sounds like a dud battery, it wouldn't be the first time a new battery turned out faulty. A couple of voltage measurements would make things clearer.
Yes , but even if it is borderline it is sometimes enough to get it started .
A good check of connections is the first thing to rule out.
Reply to Audi 80 92 2.0 l serious battery drain in the Auto Electrician Forum area at ElectriciansForums.net
I am an 80-year-old retired disabled senior citizen. About a month ago we purchased a used Ameriglide Horizon Stair Lift for our stairs to our...
Hi, My Peugeot Boxer 2.0L (X reg 2000) petrol based campervan has developed a problem. We were away last weekend and when I tried to start the...
Serious power drain on battery on Audi 80 1992.30 mins after turning engine off no battery power won't start.ALL main components seem fine.After...
My view on life, in any field, is not to produce more but to consume less. Everybody told me this is a very eccentric weird mentality. Perhaps...
8 am, cold morning I started my 3 litre Toyota Hilux as normal, drove 20 miles to a meeting but left my headlights lights on at 8.25... doh. 11...
10K
Squid
S
