Discuss Back lit bell box in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all can a bell box be made back lit thanks
Are you trying to make an existing box back lit by sticking some leds in it or, as above by @brains-lans , do you want to buy one with this feature?
You should have an abundance of options now telecom as stated above and deltabell+ by pyronix, all depends on what brand your using
Reply to Back lit bell box in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi, I bought a Ring wired bell thinking, easy, just replace the current doorbell. Now I'm hunting down how to bypass the chime but am unsure of...
Has anyone used or fitted this type of back box ? It is a 1G & 2G
I used to fit Bell door entry systems all the while about 20 years ago but I'm a bit rusty on them now, am I correct in saying if you use a DC...
