M
Mikey2017
Hi all,
I need to change my extractor fan which is in Zone 1, I have found a extractor fan as below for Zone 1 that does not need a separate transformer, as long as a RCD is present. Will the current RCD's be sufficient? I know the RCD is working, as I connected the wires wrongly when testing the old fan and it flipped.
Any advice will be much appreciated, thank you!
Monsoon IP45 Silence Axial Extractor Fan 100mm with Timer £39.92
https://www.electricalcounter.co.uk...ial+Extractor+Fan+100mm+with+Timer/2612098060
My consumer unit:
Old existing fan:
My consumer unit:
Old existing fan:
