For PIR fans with timers, Does the PIR work independently from the light switch or does the light switch need to be on for the PIR to operate the fan?
The fan is completely independent of the light source and fed through a spur . That is the intention anyway.
it is possible to adapt it to suit your needs though, ie an override from the switched live to keep the fan running if the pir cannot be reactivated by someone in a shower cubicle.
