Discuss being in a apartment and pulling the breaker in the UK Electrical Forum area at ElectriciansForums.net
F
fastracecars
I'm moving into a apartment I use 5 300 watt incandnence light bulbs. I'm worried I'm going pull the breaker how high can I actually go. The lights draw less then what is rated usually.
Welcome to the forum fastracecars :)
Just a few questions to start of with, you are down as Canada, is your question related to the local 110/120v supply or when you say you are moving, are you moving to the UK as this is the basis of the forum although your question isn't too much of a problem as long as we have all the location details.
Reply to being in a apartment and pulling the breaker in the UK Electrical Forum area at ElectriciansForums.net
I'd appreciate the wisdom of the find minds here regarding this job. Yes, I've drifted into Wales again.... An extension is being planned as...
  • Locked
5K
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
Hiya, I live in a pretty old apartment in Japan. There's only one wall in the whole apartment that has a screw to allow to connect a power cable...
Hi all, just a quick one to ask about an issue I'm having with my EV charger. I'll give a little background first but ultimately I want to know if...
