M
Martin G
I have some 20mm conduit going to the lights in my garage. I've wired them up using 1.5mm T&E in the conduit rather than conduit cable.
I'm looking at routing my garage door opener cable in the same conduit, however from what I understand you cant mix low voltage cables with mains. As the lighting cable is already double insulated, am I ok to run the bell wire alongside the T&E or must I also use T&E for my garage door opener rather than bell wire?
Cheers
You will have to seperate them, the current passing through the lighting cable will cause interfere with garage control cable, probably worse to put them in the same conduit. I remember a problem where a door bell cable was ran along side a socket cable, when the Hoover was used on the socket near the bell wire, the door bell would ring!
No as every cable sharing the same conduit should be insulated for the highest voltage present.
Cheers
Your lighting is at LV
ok Pete. fine. bit hung over from 1/2 bottle famous grouse last nite.
lightweight my arse. if i'd drunk the whole bottle, i'd have to buy another one for tonite. state pension only goes so far. got to buy smokes as well as booze. then working does the luxuries like food, diesel, bills etc.
Bellwire alongside T&E in conduit
DIY Electrical Advice
Thread Tags
Martin G,
Mark42,
