littlespark
Staff member
Supporter
Patron
yes, trunking, not pipe.
What happened is, I’ve got a job fitting 3 compartment dado trunking over the weekend, got started this afternoon, opened up the packs of trunking, and it’s this shape.
This wasn’t noticed when delivered as it’s packed face to face with another with ends covered.
The plastic is stuck like that. There’s not enough flex to straighten it for the lid to hold it.
I can’t get a replacement quick enough, so what’s the solution?
I could cut it along the join, and leave it hanging? Hopefully the lids can hold it in place… or maybe heat it up enough to soften it? Boiling water from a kettle?
There are 2 lengths like this. The other 2 are straight…. But the job asks for the entire 12m…
Won't the lid slide in from the good end?
Hit it with a hammer and some wood.
Might be an optical illusion, but it looks like the bend is mostly confined in one area. Even if it's not, you could try cutting a few vertical slices through the separating dividers (like slicing a loaf!), all the way down to, but not through, the back. Say one in the middle of the bent area, and one at each end, using a hacksaw or similar. May require more?
So in theory that should restore flexibility, at least where the slots are, and you could hopefully screw the back flat on the wall (probably multiple fixings required} and that could pull it flat enough to allow the lid to close 🤔🫣
Don't know how legit that might be wrt the "separation of circuits"! There's always silicone sealant 🤪
i tried just squeezing it together, to the size of one of the socket boxes... but it pulls the back away from the wall.
The other affected length, the bent part is right in the middle, so it might be ok.
If i could just soften the plastic a little so it can be closer to straight. It doesn't have to be perfect... just better than it is.
Would PVC solvent glue soften it enough? Fit the lid to keep it under tension, and just brush some glue along that connection joint.
If not, i could cut along, then use the glue to repair it after.
There is only power going in.... no data or anything.
I agree a heat gun is more likely to do it than adhesive.
Apologies for previous stupid suggestion, mis-understood the problem, even though it was staring me in the face 🫣
Hair dryer should get it hot enough.
