Discuss best fan for kitchen in the UK Electrical Forum area at ElectriciansForums.net
ExArmy
What do you think the best type of extractor fan is best for a kitchen? timer off the lights, humidistat, humidistat and timer?
I can only fit a 4" one, i know 6" is better and i would but it has to fit into an existing duct. a 4" fan will satisfy building regs so thats all that matters anyway.
We recently fitted a normal fan in a new build kitchen controlled by a lightswitch only (customers request). Just another option for ya!
TBH I'd say just run it off it's own switch if it's for domestic use. When the steaks and toast are burning a humidistat will not pick it up and if the kettle is boiling the fan may come on when not needed. If you can get one with variable speed it may suit better.
What sort of kitchen is it? Domestic or commercial and what does the customer want?
I'd go with the manually operated fan, is it for a hob or the kitchen generally?
I can't get a 60l/s 4" centrifugal fan.
regs say 30 don't they? infact no i've just checked you'r right. well looks like i'm gonna have to run some ducting accross the top of the units and connect up to the extractor hood, if the fan is above the hob it can be 30L/S
The extractor fan should be mounted as high on the wall as practical and preferably less than 400mm below the ceiling.
Intermittent Extraction:- 30 litres/second adjacent to hob. 60 litres/second elsewhere in kitchen.
Continuous Extraction:- 13 litres/second.
Building Regulations Approved Document F:2010 Tables 5.1a & 5.2a
Reply to best fan for kitchen in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
So today I was coring a 6 inch hole for a kitchen fan, now I cut my hole in the kitchen plasterboard and used a long sds bit to drill out the way...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
