Discuss Best way of supplying underfloor heating in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
At a rewire today, client has decided he wants underfloor heating all through his house. This is what will be heating his house. Downstairs it’s 4 small bedrooms and a small hallway, upstairs he has a dining room and a very large living room. Never done underfloor heating before, I was going to split it into 2 rings, upstairs and downstairs. Anyone else more experienced in this and can give me any advice on it?? Surely his bills are going to be massive heating his house this way
Very much depends on sizes of rooms, manufacturer of mat, etc. Some mats run at 200w a square metre which would put bedrooms at 2-3kW each. Living room is defo gonna require a couple of supplies and possibly a contactor setup depending on if the client want's it to be controlled by one or multiple stats.
Said to him living room will probs need to be split into 2 and 2 stats, he was okay with this. Might say to him to get the 150w per square metre to keep the load down as low as it can be
What flooring are they having? Tiles, wood, carpet? No point in bedrooms and I’d limit it to rooms with tiled floors ... but as above ...expensive heating option.
Says he’s planning on doing
says he’s planning on doing a line down each side of the bed and across. Not under the bed, dont even know if that is possible as I’ve never done it before and not sure how to calculate the load if he’s not doing the full room
You can fix UF heating mats into any area configuration you like, you just need to know the area and match with manufacturer sizes. What flooring are they having?
If you've never done it before I'd steer clear of this one until you've cut your teeth on something more manageable like a bathroom or two.
Its normal not to install UFH under fixed furniture like a bed which is unlikely to move so sensible on clients part.
The UFH will be dependent upon type of flooring and could be mat or loose cable!
The bills will astronomical as previously said!
I’m not doing it I’m just responsible for running the supplies for it. I defos won’t be going bel
im not going to be doing the mats I’m just responsible for getting the supply’s to them
If you’re not doing the matts you’ll need to tie in closely with whoever is to find out manufacturers requirements, loading and design circuits accordingly. I’ve run small matts off FCU’s from a RFC and also run separate dedicated radials.
and bear in mind that the manufacturer willnot honour warranty if the installer is not a fully fleeced paid up scam member.
Presumably you know where the controllers are being positioned and where the feed and thermostat for each mat are going ? ??
Hi,this sounds like a hurried decision,by the customer,
If you have not been asked about supplies for ventilation,and not noticed any upgrades in insulation,then a couple of rows around a room will not function as hoped.
Reply to Best way of supplying underfloor heating in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hi. We have moved into a new build house in Feb this year that has infrared underfloor heating and an economy 7 tariff. For info we also have...
