This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
J
Jimmyb
hello all, ive been asked to wire up a s plan system with an extra zone and with not done one before can any one give any point or advice.
thanks.
jim
When you say extra zone, is there an extra zone valve also???
You may need a 3 channel programmer instead of a double, other than that it's dead simple. Theoretically you could have 'n' number of zones providing there is a zone valve for each one.
sorry id posted in the wrong section, thanks for that i just got told a 3 channel programmer wouldnt work and to use a 2 channel for hot water and 1st zone then a additional for 2nd zone.
i'll post diagram i was given just for the info.
Looks like the additional zone is working as a night zone from a programable stat. Seen this done a few times when night time temperatures are to be maintained when timeclock is off. ie the client does not want temperature to drop below say 10 degrees.
Seems the 3rd zone is independant of CH1 and HW. It has it's own stat and valve so basically you have additional SW form 2 port valve (orange) calling pump and boiler. As I said, theoretically you could repeat this to the nth degree.
