Hi all,
UK: The RCD on the circuit my boiler is on has tripped, I have a water supply issue in my area today and switched on my hot tap for a moment or so and there was low pressure, could the low level of water in a modern boiler (Logic) cause the RCD on the consumer unit to trip?
I'm unsure if it's a fault elsewhere as earlier on before the water supply issue everthing else on the circuit was working as normal, sockets etc, and the circuit has not tripped since I have swicthed the boiler off at the spur whilst waiting for the water supply to be restored.
Thanks,
James.
Thanks,
James.
