Discuss Boiler wired from lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
C
concerned321
Hello. I'm just looking for a bit of advice.
I had a new boiler fitted a few months ago. An electrician came and wired it up and left me a Minor Electrical Installation Works certificate.
ive just had a plumber round to check the work and he says the electrician has wired the boiler from the lighting circuit and he shouldn't have done this because it is a 6 amp switch in the fusebox.
The electrician says it is ok because he has fitted a switch next to the boiler with a 3 amp fuse in it.
could you tell me which one of them is right please?
Many thanks
unconventional, but not a problem. a bathroom fan is usually fitted with a 3A fuseand that's wired from the lighting.
Reply to Boiler wired from lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Had a new unvented Boiler fitted as the old one had reached the end of it's life. Electrician mentioned that it might be worth replacing my fuse...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
