Discuss Bonding Gas and water mains. in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I need to bond the gas and water at a friends house..never done it before as I worked mainly on sites. My times just out, where’s the best place? Gas meter is outside in a Box so would I just clamp onto the metallic side just before it enters the house? And the water, not entirely sure where it enters the house..any help would be appreciated thanks
Gas within 600mm of the point of entry to the building, water as close as possible on the consumers side of the SC.
But as above, check bonding is required, plastic incomers mostly negate the requirement for main bonding.
main bonding yes
So say for all CU changes, EICRs etc, you test the Gas and Water requirements, and not just say bonding in place of not as the case maybe? Could you point me the the Regulation that endorses your claim please?
10mm Main bonding for the gas in the meter box is fine. On the consumers side of the meter rather than the distributor.
As for water, you would need to find the stop cock inside the house. Ask your friend as most customers know where their stop cock is. If you can see a plastic pipe feeding into the stopcock then I doubt it will need bonding as this will be an insulating section where it enters the house.
Reply to Bonding Gas and water mains. in the UK Electrical Forum area at ElectriciansForums.net
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
Hi forum members, I hope someone can assist with my enquiry. I have been advised that to comply with BS7671 Reg 132.16 my solar and battery...
