No change.
I think its about time that we sparks took on the IET too - they are a bunch of numpties - how can we influence changes??
It strikes me that 3 year intervals should be sufficient for upgrades to the main books, possibly supplemented with a few "free" pages after 18 months.
I suppose you can to some extent... EDIT, I've just noticed you've got until midnight TODAY! :-)
IET Wiring Regulations updates - IET Electrical
Up until the 16[SUP]th[/SUP] if you look in the front of the book revisions and supplements were issued. No profit in doing that.
I'm not an IET member!
Could all the members on here all "have their say" and complain about the regularity of the updates and also request that the IET get the Plain English Society to review the document prior to publication - that would be a great step as it would delay it by years!
Stop being such a drama queen. What pray have i said, above makes me a Drama Queen?? lol!!
Now Im like a sponge and willing to learn the errors of my wicked ways. Im man enough to admit if Im wrong and change how I do things… so …
can you explain why in your opinion, for an addition or alteration to go ahead, an existing undersized and difficult to change bonding conductor must be upgraded at extra cost for the client?
Why not you tell all of us, why you WOULDN'T?? Or has doing things correctly/properly, something else that's being kicked into touch, in favour of saving a few quid!! Shame you don't use as much effort to do things properly, than you seem to, finding ways to circumvent...
There is a reason why the main bonding connection should be as close the shut off valve/stop cock. It has nothing to do with size of copper pipes and Bonding conductors, and everything to do with circumventing any future plastic piping being inserted into the system. Which is why main bonding should be whenever possible, BEFORE any branching of a systems pipework!!
What's the point of bonding any service pipework that can be left totally isolated at a stroke, by a dumb plumber, leaving the actual extraneous incoming pipework without any main bonding with the installations MET!!
Thought I mentioned why I wouldnt, but as you may not of read the first bit...."guidance tell us", ie. ESC guidance...and because if bonding is present, but undersized, and has been in place for a considerable amount of time, with no sign of thermal damage, then I see no real or economic advantage in upgrading....haveing said that I would note this on the certificate and recommend upgrading to achieve compliance with the current Regs.
So would you upgrade a bonding conductor? one which would be difficult to replace at a reasonable cost, causing no or little damage ? and why?
I take it you're talking about in situations where 6mm is the existing size of the main bonding cable, where i've been talking about 4mm, or where no bonding conductors are in place. So if i've misread or misunderstood, .....my apologies!! lol!!
Tell me would you leave existing 6mm main bonding in place with when undertaking a CU upgrade??
No need to apologise, maybe my posts are sometimes unclear or badly worded.
But, yes, I have left 6mm bonding in place and on TNC-S systems when changing a CU, and all of these instances were where it was impractical and costly to upgrade. I mean this with no disrespect, but the reality of life is not always an ideal world and is full of work arounds dictated by cost and practicalities as Im sure you know.
Just to start an argument. (condensed version)
OK what started this was reading a post where someone was asking why there house should be ripped apart for an earth wire.
The first rewire I did was my own house and this has been puzzling me ever since. I did all the plumping myself including the gas. Everything was bonded and as was as then required supplementary equipotential bonded. I had one hell of a struggle getting a 16mm to the gas meter, water wasn’t too bad. Supplementary equipotential bonding was in 6mm. All the pipe was copper, soldered throughout except for about 18” of lead which I couldn’t get rid of and that I plumbed.
Now the bit that puzzled me, where is the best place to make main earthing connections?
Battle all the way through a house to connect an inferior bit of 10 or 16mm² to a remote point or somewhere local
With standard copper pipe or 0.8mm wall thickness:
π x (Do/2)² - π x (Di/2)² = CSA mm²
Where:
Do = outside diameter
Di = inside diameter
Therefore:
15mm pipe = 35.69mm²
22mm pipe = 53.28mm²
Cross sectional area and therefore resistance is directly proportional.
So if we compare the linear resistance of the smallest 15mm copper pipe against the largest normally used 19mm² CPC the pipe is 2.23 times better.
I know this is against all that is in the Bible (red with green stripes) but I give you this argument:
A central point would be electrically the best point.
Right where’s my tin hat! Incoming FLACK!
Tel:
so then, the fact that i have bonded my gas pipe where it runs past the CU, instead of struggling to get a 10mm cable 20ft to the gas meter in the garage is not, after all, bone idleness, but has a good sound basis in mechanical and chemical engineering, not to mention the lower resistivity of 22mm copper pipe against some cable made in china. a good argument there , tony, can't fault it.
Me:
I knew the moment I started to write it I would get the Bible (red with green stripes) quoted at me but you have to look at:
Logistics / practicality
Basic physics
By running to a remote point you aren’t making the situation better.
Ohms law won’t change for the IEE!
I’m not saying go against the regulations but I’m trying to point out using physics that the regulations aren’t always right.
Drawing “A” is based on a typical installation based on the GAS pipe only.
Drawing “B” is based on Tel’s instalation.
If you work out from linier resistance “B” is 285% better,
QED the regulations aren’t always right.
Every installation is different. Service positions can be any where.
So use common sense.
Now this is the sort of post that keeps me coming back for more..
as long as there's no likeleyhood of plastic pipe being inserted between gas meter and boiler, ( not going to happen with gas , is it?) then hours of work and disruption have been saved by doing as pic. 2.
Where:
Therefore:
Tel:
Me:
Basic physics
^^^The above is a post by someone who completely misses the point of main bonding.
^^^The above is a post by someone who doesnt completely miss the point of main bonding.
The reason for bonding at the point of entry is to be sure that whatever happens to the pipework on the consumers side of the incomer the bond will still serve it's purpose. That wont be the case if it's bonded somewher in the middle.
Perhaps you could explain to me by using maths and physics just what I don’t understand.
Don’t quote the IET regulations. Use logic as a base for your argument.
Plastic pipe for domestic gas? That a new one on me. The supply will no doubt be plastic, so why battle all the way to the meter to connect as close as possible to a non conductive pipe.
The sites I’ve worked on were major gas consumers. The high pressure gas system was bonded as near to the substation MET as we could get, not the intake point.
